Parkzone's Fw-190A-8 with Drop Tank
Old 05-16-2013, 02:59 PM
Default Parkzone's Fw-190A-8 with Drop Tank
Looks pretty cool....Nice wide gear too!
From Parkzone:
Specs:
Wingspan: 43.3 in (1100mm)
Overall Length: 37.0 in (940mm)
Flying Weight: 44.4 oz (1260 g)
Motor Size: 15-size brushless outrunner, 950Kv (installed)
Radio: 4+ channels minimum (6+ for drop tank and retract operation) transmitter (required)
CG (center of gravity): 2.90 in (74mm) back from the leading edge of wing at wing root
Prop Size: 9.5 x 7.5
Speed Control : 30-amp BL ESC (installed)
Recommended Battery: 11.1V 2200mAh 3S 25C LiPo (required)
Flaps: No
Retracts: Optional
Assembly Time: Less than 1 Hour
Is Assembly Required: Yes
During World War II, few sights could make an Allied pilot’s blood run cold like that of a Focke-Wulf 190 headed his way. So fearsome was this fighter’s reputation that it was known to friend and foe alike as the “Butcher Bird.” In the hands of Luftwaffe aces like Kurt Bühligen, it was practically invincible.
The ParkZone® Focke-Wulf 190A-8 park flyer is a gorgeous recreation of this legendary aircraft that no warbird lover should be without. Modeled after a variant that first flew in 1944, it bears the trim scheme and markings of the airplane flown by Kurt Bühligen near the end of the war.
Other scale touches include molded panel lines, a functional engine fan and a painted pilot figure as well as instrument panel, gun and cowl details. It’s equipped with a 15-size, 950Kv brushless motor that’s been paired with an E-flite® 30A Pro ESC. Powered by a high-output 3S Li-Po battery (sold separately), this combination will make everything from high-speed strafing runs to dogfights with other ParkZone warbirds an absolute blast.
For a truly spectacular flying experience, add the optional drop tank release and electric retracts.* The model has been designed to make installing these options quick and easy, and its Spektrum™ receiver has all the channels you’ll need.
*Requires E-flite Servoless Payload Release (EFLA405) and E-flite 10–15 size 74-degree electric retracts (EFLG115), both sold separately.
ID:	168881   Click image for larger version
ID:	168882   Click image for larger version
Old 05-16-2013, 04:21 PM
toddyrotten
toddyrotten's Avatar
I want one!
toddyrotten is offline
Old 05-16-2013, 06:17 PM
Very nice! I'm glad to see the retract option. In my mind this pretty much confirms they are on board with that. Had to customize my own on my 1st gen Corsair.
Old 05-17-2013, 01:12 AM
Very sweet plane!
Don Sims is online now
Old 05-17-2013, 02:52 AM
mattman0182
Luftwaffe Ace
mattman0182's Avatar
Very nice. Still need a micro axis plane. But this one is nice no doubt. I don't like the iron cross on the tail, its just too much.
Love everything else though. And the price is right in line with the Fly zone 190.
Judging from pics alone it looks a bit better made than the Fly zone.
RCERS, would you by any chance be able to review her at some point?
mattman0182 is offline
Old 05-17-2013, 03:30 AM
Iron cross on tail is substituted for the actual swastika of the WWII full scale aircraft.
Rather than potentially offending people that do not know the > 3000 year history of the symbol prior to adoption by the Germans in WWII... its being deleted/replaced on just about any modern scale models.
This trend to only associate the symbol with its rather brief use by WWII Nazi Germany is insulting to the cultures that still see it in a positive light due to its longstanding positive meaning.
http://en.wikipedia.org/wiki/Swastika
The swastika (卐) (Sanskrit: स्वस्तिक) is an equilateral cross with four arms bent at 90 degrees. The earliest archaeological evidence of swastika-shaped ornaments dates back to the Indus Valley Civilization as well as the Mediterranean Classical Antiquity. Swastikas have also been used in various other ancient civilizations around the world including China, Japan, India, and Southern Europe. It remains widely used in Indian religions, specifically in Hinduism, Buddhism, and Jainism, primarily as a tantric symbol to evoke shakti or the sacred symbol of auspiciousness. The word "swastika" comes from the Sanskrit svastika - "su" meaning "good" or "auspicious," "asti" meaning "to be," and "ka" as a suffix. The swastika literally means "to be good". Or another translation can be made: "swa" is "higher self", "asti" meaning "being", and "ka" as a suffix, so the translation can be interpreted as "being with higher self".[1]
The symbol has a long history in Europe reaching back to antiquity.
https://en.wikipedia.org/wiki/Indus_Valley_Civilization
The Indus Valley Civilization (IVC) was a Bronze Age civilization (3300–1300 BCE; mature period 2600–1900 BCE) in the northwestern region[1] of the Indian subcontinent
It really should be left on the scale models when appropriate. Its a part of history that it was misused as a symbol for an oppressive dictatorship. Deleting it doesn't change the fact.
Old 05-17-2013, 10:41 AM
mattman0182
Luftwaffe Ace
I agree with you one hundred percent. Stalin killed just as many people, yet no one has problems with the communist symbol of the USSR.
As for this FW. They should have just left the tail blank. It looks silly.
Old 05-17-2013, 02:17 PM
Not sure if I will get the review yet. Time will tell.
The Iron Cross is COMPLETELY understandable. It is actually illegal to display the Swastika in public in some parts of the world.
This is a common answer from RC model outlets. Horizon offers the correct Swastika for sale for you to change but this makes the model exportable to all parts of the world. Then modelers that can change it - certainly have that option.
Having spent a fair bit of time in Germany (one of the illegal countries) I can tell you the emotion that comes with that symbol is still very raw.
Old 05-17-2013, 05:01 PM
mattman0182
Luftwaffe Ace
Wow I did not know Horizon offered the correct Swastikas. Are they listed on the site? As a history and aviation buff, the closer to scale looks the better for me.
The Soviets did just as many evil things, or possibly more, and their symbol is seen worldwide with no restrictions. I just don't get that.
I do take a lot of pride in my German heritage. There are a lot of painful things about history, but we cannot just try to pretend they never existed.
Still, they should have just left the tail blank. It looks silly because it is overkill with the crosses.
Mattman, I agree it's better to leave the tail blank. If you look on Parkzone's site, at least some of the pics have a blank tail, so I'll bet the final version will be blank, and swastika's sold separately. There is a 'Decal Sheet' in the spares list, but no pic of it.
Edit: Wow! We were typing at the exact same time.
Old 05-17-2013, 05:21 PM
Yep agree the blank tail might be the best option as the decals/stickers don't easily come off this stuff.
At any rate - it is an option for those who wish it.
I think they have dropped the retract price - and are now using a aluminum trunion. Great improvements! It appears Horizon is paying attention to the market. While I strongly suspect they will never be the price leader they will be the quality/service leader. The "other" receiver ready stuff from China is not that impressive to me, yet.
Old 05-17-2013, 10:16 PM
road king 97
old hat
road king 97's Avatar
I was talking to a fellow flyer today who was upset that you can only use their retracts but he is still buying one. He had the bigger dynam one and said it flew real bad. joe
road king 97 is offline
Old 05-18-2013, 02:58 AM
I've got to take a close look at this one. Have had my eyes on various versions including FMS, Dynam and Top Rc(HK) I like the creature features of the Top-RC 1200mm version with the flaps, retracts with sequencer doors, nice battery access: http://www.rcgroups.com/forums/showthread.php?t=1624129
I didn't like the short, stubby, non scale legs.
I think PZ is still the gold standard for quality. Loved my T-28 and have a smaller P-51 without gear. Should come standard with retracts but they need to have a scale forward rake angle. I also hate nose overs.
Can't wait to see it at our LHS.+1 on the swastika for the tail livery. It was actually artwork from Catholic churches in Austria. But it's also a part of history that should remind us of the evil we fought against.
I would have expected it to be a little bigger.
-Hawk
Old 05-28-2013, 04:25 PM
Gary Hoorn
Chesepeake Bay RC Club
Gary Hoorn's Avatar
Default Parkzone FW 190
The plane come with a plain rudder. The Iron Crosses are in an accessory pack.
Gary
Gary Hoorn is offline
Old 05-28-2013, 04:53 PM
Das is gut! After close looks at Flyzone, TopRC, FMS and Dynam, I'm going with the Dynam. I've had great luck with their models and it's more in line with my addiction budget. Plus, it comes with the swastika on the tail.
I'm sure the PZ version will be a big hit as the masses see it at the their LHS. Look forward to hearing flight results.
Old 05-28-2013, 05:51 PM
mattman0182
Luftwaffe Ace
Aren't the Dynam birds slightly larger than the others? Wonder what the minimum space requirement would be. I love thelooks of the Dynam BF109 but it would likely not be a good 4th plane, and is probably slightly larger than id want.
Wouldnt mind seeing a review of that Dynam 190 when you get it.
Horizon needs an Axis aircraft in their UM line, thy have none.
I love the new PZ 190, but right now shes out of my price range.
Old 05-28-2013, 08:04 PM
Matt,
http://youtu.be/rTMdjpgt41g
This one's more like $ 135.00 with retracts., not $270.00 Note the LG mod at aout the 5 min mark. All but completely eliminated nose overs on grass.
Old 06-22-2013, 05:18 PM
papabatman
papabatman's Avatar
any one want a ride on my fw 190 turn you sound down motor noise look for the surprise at the end
[media]http://www.youtube.com/watch?v=971ZoNju0M4[/media]
papabatman is offline
Old 06-22-2013, 05:26 PM
Now that was a low high speed pass - just a touch too low!
Old 06-22-2013, 06:01 PM
papabatman
papabatman's Avatar
lol or a touch and no go
Old 06-22-2013, 10:57 PM
road king 97
old hat
It was a merely flesh wound ,get out the gorrila glue to fill in any voids and she will be as good as new. joe
Old 06-23-2013, 02:54 AM
papabatman
papabatman's Avatar
all ready fix did it at the field and flew again
Old 06-23-2013, 02:58 AM
mattman0182
Luftwaffe Ace
How does it fly compared to that FMS 109?
Old 06-23-2013, 03:21 AM
Did I see right? The video says it's a PZ, but I see a 3300mAh battery in it? Is that the surprise? Or is it really an FMS?
Old 06-23-2013, 04:33 AM
papabatman
papabatman's Avatar
so the story goes like this. i burnt the stock motor on 4s so i gutted it installed a scorpion SII 3026-8 1190 kv 90 amp esc cam 10x8 prop runs great on 3s but ready for a 4s. the surprise was the landing gear hit a tear in the run way doing a fast wheel burner ripped the wing right out from the fuse that was it. having a blast with this new toy. my shelf i don't like the fms 1400 size warbirds to hard to upgrade and the foam is soft. i do like the 1100 durafly easier to up grade but still to soft of foam for high speeds that is why i am a parkzone fan. don't get me wrong the fms birds fly great just to slow for me.
Page generated in 0.11916 seconds with 16 queries
