Swastika Decals.
Old 06-18-2013, 11:03 PM
mattman0182
Luftwaffe Ace
mattman0182's Avatar
Default Swastika Decals.
Wondering where I can get some for my new 650mm BF-109. I think the Parkzone ones will be too big so that is not an option.
I do not intend this to be a swastika political debate thread.
I was just wondering if there is anywhere that sells something I could use.
Just FYI, it would go on this.
http://www.nitroplanes.com/95a387-21792-bf109-arf.html
mattman0182 is offline
Old 06-18-2013, 11:30 PM
Have you searched some of the plastic model sticker (decal?) suppliers? i don't know them well, but I know they are out there, and probably have a wide variety available.
Old 06-18-2013, 11:32 PM
mattman0182
Luftwaffe Ace
Many are water slide decals. Would that work on foam?
Old 06-18-2013, 11:51 PM
Chucksolo69
Yes, they will work on foam.
Chucksolo69 is offline
Old 06-19-2013, 12:08 AM
Easy enough to cut your own the size desired from Monokote trim sheet...
One of the simplest graphics to cut.
Old 06-19-2013, 05:05 AM
have you tried this place......they have the materials to make custom as well.
http://www.pyramidmodels.com/shop/se.../printed_vinyl
Old 06-19-2013, 06:55 AM
You can grab water slide decal sheets for you inkjet printer, if you have one, and print your own decals.
Old 06-19-2013, 04:39 PM
Ebay ... Hobby King ... there are lots of places online on Ebay and HK have them in the hardware listing.
I have a Graphics Shop in town that makes whatever I want ... I create a PC graphic .. put on a USB stick ... take to them ... couple days later I have in my hand for peanuts. I can make many of them with vinyl etc. - but given their prices and quality ... no contest.
Last order was :
4 x 5" RAF roundels
16 x 2" RAF roundels
8 large USAF
Various text decals ... ROYAL AIR FORCE ... RC-LV .... NCL-GB .... (8 of each)
Total price $6
Old 06-19-2013, 11:37 PM
What do they make for you? Water slide decals? Or ...?
Old 06-20-2013, 12:01 AM
Two types ...
Normal vinyl self-adhesive with clear border.
and
type that has backing ... where you peel away one side leaving letters / decal on the face tape ... you then place in position and rub the tape transferring the thin vinyl to the model. Peel away carefully the face tape - leaving the decals behind. These have no border and are thinnest giving best look.
They will also create water-slide if I want ... but with foamies - I prefer the above two types as more resistant to rash etc.
My Red Arrows here has both types :
Old 06-20-2013, 12:16 AM
mattman0182
Luftwaffe Ace
Wow looks like I have several options. I'd prefer the vinyl type but I'll do some looking.
Old 06-22-2013, 01:01 AM
Any good to you ?
Old 06-22-2013, 02:00 AM
mattman0182
Luftwaffe Ace
wow that's perfect! would I be able to print that onto a vinyl paper or something?
Old 06-22-2013, 03:47 AM
What you could do is copy the file to a USB stick ... go to a Graphics shop ... tell them the size you want for each part ... they will then create for you in the format you require. The graphic is actually for a FW190 ... but the basics are same.
If you have difficulty getting the graphic from the attached .. then PM me your email and I will send you the graphic file - do not put any email address on open post - bots can pick it up and then you receive auto-spam ... I have other graphics as well ... see below.
ID:	169519   Click image for larger version
Name:	jet RESCUE.jpg
ID:	169520   Click image for larger version
Name:	Snoopy 640x655.jpg
ID:	169522   Click image for larger version
Name:	USAF roundel.jpg
ID:	169524   Click image for larger version
File Type: pdf
File Type: pdf
Old 06-22-2013, 02:05 PM
I use Callie....
http://callie-graphics.com/
Old 06-24-2013, 12:38 AM
Callie does a great job ! I need to print out the Swaztika for the FW-190. What paper should I use? I have clear photo paper and waterslide decal paper
Old 06-25-2013, 01:12 AM
mattman0182
Luftwaffe Ace
Where can you get waterslide paper?
Will it work with any inkjet?
Old 06-25-2013, 01:24 AM
I got a few sheets from a club member. Google it. Ink Jet will work . Laser is better. I also use decal sheets found at Staples. Can get white or clear. These are sticky as in stickers. In the end, Callie makes the best graphics around. She did my Cessna 310 and it turned out gorgeous. Viinyl is the way to go but the others work fine too.
I'm not the best at applying decals. Always seem to get goobered up in one way or another.
Old 06-25-2013, 01:32 AM
mattman0182
Luftwaffe Ace
I did not see just a swastika on the Callie site so I guess I would have to special order it, which I may end up doing on payday.
I'd love to have the Hartmann black tulip on the nose. But he flew the 109G and mine is a 109E so it would not look right anyway.
Old 06-25-2013, 01:54 AM
I saw some swaztika's at my LHS. A carded item where they keep the decals. Had numerous sizes in the package.
Old 06-25-2013, 01:58 AM
mattman0182
Luftwaffe Ace
If only I had a LHS lol
Old 06-25-2013, 05:50 AM
Just send her an email. Most people don't advertize Swaztika'a Might be mis-construed as a Tea Party memer and then the IRS will be all over you.
Old 06-25-2013, 08:17 AM
Only some real 109 experts would see the difference between the G and E... and then they still might not know which one Hartmann flew...
Old 06-25-2013, 01:29 PM
Glacier Girl
Kamikaze Ace
Glacier Girl's Avatar
If you use the printer type decals it's best to give them a top coat of clear paint.
One or two LIGHT coats of clear will make em last longer and not smear.
Glacier Girl is offline
groundrushesup
Informal Clubs
1643
08-31-2021 08:30 PM
Sky Sharkster
57
11-30-2014 04:39 PM
theoldALFER
ParkFlyers
02-16-2011 03:32 AM
Quick Reply: Swastika Decals.
Page generated in 0.12962 seconds with 20 queries
