Aerodynamics Discuss the concepts of aerodynamics here
Servo tabs for a twisty wing?
Old 08-03-2019, 01:47 PM
Steverino
Default Servo tabs for a twisty wing?
I've never flown a "twisty wing" slope glider. It's my understanding that a 'pitcheron' uses the twisty wings for both elevator and aileron function, and that a 'wingeron' uses the twisty wing for only aileron use.
In reading on forums I've learned that these gliders need powerful servos to twist the wings.
While digging through my big box of wrecked plane parts I got to looking at a glider wing half that had a servo mounted in it that operated the aileron, and I wondered if that aileron could instead be used as a 'servo tab' to twist the wing panel.
I'm thinking that someone must have tried doing it by now.
Steverino is offline
Old 08-03-2019, 02:20 PM
Steverino
Well I got to thinkin' and for it to work the servo has to be mounted in the fuselage, not the wing.
The servo needs to operate the tab in such a way that the tab moves back into the neutral position when the wing twists as much as the pilot wanted.
11-02-2021 02:03 PM
Flite-Metal
548
08-25-2021 01:35 PM
lakeside1000
Delta & Flying Wings
12-29-2011 05:49 PM
WayneG
05-29-2011 09:37 PM
Quick Reply: Servo tabs for a twisty wing?
Page generated in 0.06880 seconds with 10 queries
