Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric R/C Airplanes > Combat
Old 06-25-2013, 09:56 PM   #1
madmickey
Default gremlin electric conversion
Hi
I acquired a glow powered Gremlin from a friend and I would like to convert it to electric o I can fly it without assistance. Can anyone give me some advice on a good motor/esc battery combination.
madmickey is offline
Old 06-25-2013, 11:03 PM   #2
Its a .25 glow power (recommended) airplane...
So E-Flight Power 25 or rough equal power.
There are MANY appropriate motors that are roughly equal. Most will cost less. This one gives you some good numbers for comparisons.
Tacon 25 is a nice one... OMG power with a APC 12X6 on 4S.
It thinks its a .60 turning that prop close to the rpm I got from a OS .61 FX with a 12X6.
(yes, I have one... on a Commander 40 EP)
60 amp ESC (may as well have excess ESC rating since they are getting cheap) The Dynam (Detrum) ESCs are good and inexpensive. Just a couple bucks extra for 60 amps... do it.
Your main issue will be getting the CG correct. It has a nice opening on top for battery access but the fuselage is SHORT and expects something quite a bit heavier than the .25 equiv outrunner on the nose (about 300 watts equals a .25... the 600 watt max of the Power 25 is about equal to a mild .40!)
Power 25 handles 4S fine and 3000 mah 4S would haul that flying wing around very nicely. You'll be outrunning Gremlins with .46's because you'll be lighter.
Old 06-26-2013, 01:08 AM   #3
4kW  Outstanding Contributor Award  3kW  2kW
Friends: (21)
Originally Posted by madmickey View Post
Hi
Check out one of those computer programs such as www.motocalc.com for a bit of info before spending $$$$. This program is free for 30 days, then $39.
As indicated in this thread, you can select from a very wide range of power systems, from a few dozen bucks, to a few hundred bucks. Some of the cheap stuff isn't worth installing, some of the higher $$$$ units will work well.
That Power 25 size motor has a pretty good reputation. For more $$$$, check out the similar sized Hacker series motors:
https://www.aero-model.com/8_67_889/...-10S%20V2.html
For very good performance, you need about 125 to 150 watts per pound of airplane, including the motor/ESC/battery pack. So, weigh your model without motor/ESC/battery, look around for appropriate power equipment, and see what kind of watts you are running. This is where motocalc comes into its own. It will give predictions on how your model will fly, and will warn you if you are overloading anything.
DennyV
Old 06-26-2013, 02:42 AM   #4
gramps2361
gramps2361's Avatar
View gramps2361's Gallery9
Club: Rocky Hill Flying Circus
Friends: (24)
I did mine up with a eflite 25 60 amp esc 3c 3300 mah battery with a 11x5.5. I use this for the Gremlin combat with streamers. Real fun wing to fly WOT in combat is 4 minutes the battery comes down around 3.80 per cell. If I am just flying it I get around 7 minute flight mixed throttle.
You will have to move the gutter fuse forward and drill new mounting holes to get the CG right. Not hard to do. Once you get it setup and balanced right you will have a ball with it.
Here is a link that might help you out with more info and build directions. Should help you with the conversion.
http://www.racores.com
By the way I am doing combat against gas powered grelims, and I do all right. You can't go too fast as you start to shred your crepe paper ribbon not a good thing to do.
gramps2361 is offline
Old 06-26-2013, 06:27 AM   #5
If the crepe paper is cut cleanly (when they split the streamer in half the long way) it can handle a lot of speed.
I drug 35 ft of streamer behind a modified "Corostang" that was clocked at 95 mph.
Common party streamers cut in half with a band saw.
If the streamers your group cuts won't take it then a bit of throttle management may be in order. :p
Or lessons in how to cut them so they don't have a ragged edge. (fine tooth bandsaw and a good cutting guide)
Nice to see that its been done with essentially what I was recommending... and the same CG issue I expected.
Long time since I put a Gremlin together. We were using the sliding tray for mixing the elevons.
Old 06-26-2013, 11:39 AM   #6
madmickey
Hi
Okay what is the Gutter?
Old 06-26-2013, 11:58 AM   #7
gramps2361
gramps2361's Avatar
Friends: (24)
The gremlin fuselage is made from plastic gutter down spout.
In the link I posted there is a part list for the gremlin. Any idea on how old your version of the gremlin is?
Here's another link for builds on the gremlin should be a lot of help for you to convert it.
http://www.rcgroups.com/forums/showthread.php?t=1059205
Old 06-26-2013, 12:38 PM   #8
madmickey
Hi
Thanks for the link. I am pretty well versed in electrics as I fly them in my F3A planes however I thought I would put the post on Wattflyer to see what others are doing and to take the benefit of other's peoples experience. As clever as motor calc is, it doesn't always get it spot on and some tinkering is always required, Hence my post.
I wont be flying combat with it, nobody to play with up here but as a bit of fun it looks just the job.
Old 07-23-2013, 03:16 PM   #9
thrawn150
Club: Palos flyers
I have made 2 EP powered gremlins. Both with a monster power 46 4S 5000mah setup, spinning a 14 x 10 prop. It did well against the glow ones in my club in combat. It is a heavy setup but boy is it fast. Here is a pic of my second one.
thrawn150 is offline
Old 09-26-2017, 02:17 AM   #10
1kW
Friends: (7)
Working on a Suppo 3520/6 840kv model. 4lb 1oz minus wing tape and covering. 4000mAh 6s is a bit heavy but 1200watts should make up for it at 300 watts per pound on a 10x5. Gonna shred some poor little wet fuelers with this beast. Yeah it's a big battery but I own quite a few and those pesky little glow planes have some run time.
A friend at the club cut the cores and passed out kits for many of us to build. Most going nitro but I remain faithful to the electrons.Call me a purist.
Rob
Old 11-21-2017, 05:13 PM   #11
Buzzsaw
Buzzsaw
I have been flying electric Gremlins for a couple of years now. Using a Headsup 25, 60 esc ,3300 battery. I get around 3 1/2 minutes.
Buzzsaw is offline
Old 11-22-2017, 02:59 AM   #12
1kW
Friends: (7)
Nice collection. Actually I wound up running a Leopard 4250/620kv on 6s 4000mAh with an 11x5.5 apc and getting 7 minutes maximum (to around 3.6vpc). This is at wide open throttle for essentially the entire flight. Performance is matched well to the others flying .46 and .52 nitro but plane is pretty heavy at around 4.5 pounds. It is a lot of fun for playing around with tumbles and spins since there is no threat of a deadstick.
Unfortunately, this is far too hard on the batteries for my liking so wound up burning wet fuel (11 to 12 minutes) in other Gremlins. Here is a 75% I am getting close to finishing. The fuse is made from a box/sleeve that contained TIG welding wire. Because of the magenta color of it i decided to cover with primary colors and make it look like something you would find on the floor of a daycare center.lol. The ASP .21 engine is going to have this "toy plane" screaming through the air...
Here is a shot of a motor mount i devised by sawing up a $6 24" aluminum level. Great rigidity but I suggest Fiberglassing the front of the fuse with a few layers of cloth and CA.
Rob
Glider Kits? to a conversion to electric? BrianW517 Hi-Performance and Sailplanes 18 01-03-2015 03:26 AM
General Electric Conversion Questions Wrongway-Feldman General Electric Discussions 21 05-03-2013 04:31 PM
sig Aqua-Star electric conversion question harlanB Seaplanes E-Powered 6 05-28-2012 01:02 AM
conversion of J3 cub to electric hybrid General Electric Discussions 6 01-23-2011 09:43 PM
Page generated in 0.14668 seconds with 46 queries
